DNV
E2iPlayer - błąd not found code:-1330794744
Witam  mam problem z odtwarzaniem filmów w ipla . jak włączam film pojawia mi się code:-1330794744 .   Soft jaki zainstalowałem w nbox to Nbox_OpenPli.8.6_Nevo-System_NAND_10-06-201  .   Potem nadpisałem iptv plikami zadmario  po konfiguracji wszystko się zaktualizowało poprawnie.   Czytając na forum ten problem próbowałem przez telnet  zainstalować patcha według poniższej procedury:
cd /tmp
fullwget --no-check-certificate https://gitlab.com/samsamsam/precompiled/raw/master/python2.6.6_sh4_sni_patch.tar.gz
tar -xvf python2.6.6_sh4_sni_patch.tar.gz -C /
rm python2.6.6_sh4_sni_patch.tar.gz
sync
cp /etc/init.d/rcS /etc/init.d/rcS.backup
sed -i 's,/usr/local/bin/enigma2,LD_PRELOAD=/lib/libcrypto.so.1.0.0:/lib/libssl.so.1.0.0 /usr/local/bin/enigma2,' /etc/init.d/rcS
sync
reboot
reboot -f
Po wkopiowaniu całości naraz  odpowiedź wygląda tak:
nbox login: root
BusyBox v1.19.3 (2012-01-04 10:10:53 PST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
nbox:~# cd /tmp
nbox:/tmp# fullwget --no-check-certificate https://gitlab.com/samsamsam/precompi
--2019-11-13 22:03:49-- https://gitlab.com/samsamsam/precompiled/raw/master/python2.6.6_sh4_sni_patch.tar.gz
Resolving gitlab.com... 35.231.145.151
Connecting to gitlab.com|35.231.145.151|:443... connected.
WARNING: cannot verify gitlab.com's certificate, issued by 'CN=Sectigo RSA Domain Validation Secure Server CA,O=Sectigo Limited,L=Salford,ST=Greater Manchester,C=GB':
  Unable to locally verify the issuer's authority.
HTTP request sent, awaiting response... 302 Found
--2019-11-13 22:03:50-- https://gitlab.com/users/sign_in
Reusing existing connection to gitlab.com:443.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: 'python2.6.6_sh4_sni_patch.tar.gz'
python2.6.6_sh4_sni     [ <=>                ]   7.01K  --.-KB/s    in 0s
2019-11-13 22:03:51 (20.1 MB/s) - 'python2.6.6_sh4_sni_patch.tar.gz' saved [20785]
nbox:/tmp# tar -xvf python2.6.6_sh4_sni_patch.tar.gz -C /
gzip: invalid magic
tar: Child returned status 1
tar: Error is not recoverable: exiting now
nbox:/tmp# rm python2.6.6_sh4_sni_patch.tar.gz
nbox:/tmp# sync
nbox:/tmp# cp /etc/init.d/rcS /etc/init.d/rcS.backup
nbox:/tmp# sed -i 's,/usr/local/bin/enigma2,LD_PRELOAD=/lib/libcrypto.so.1.0.0:/
nbox:/tmp# sync
nbox:/tmp# reboot
WARNING: could not determine runlevel - doing soft reboot
  (it's better to use shutdown instead of reboot from the command line)
shutdown: No such file or directory
nbox:/tmp# reboot -f
Prosiłbym o pomoc.
Złe polecenia, te pliki z gitlab zostały usunięte, prawidłowe polecenia:
cd /tmp
wget http://e2iplayer.pkteam.pl/precompiled/raw/master/python2.6.6_sh4_sni_patch.tar.gz
sync
sync
reboot
reboot -f
Ale sam patch niewiele pomoże bez ffmpeg i pycurl, powinieneś zainstalować soft na pendrive, zainstalować patch i całą resztę, dopiero wtedy będzie to działać tak jak powinno.
Wykonałem tą procedurę i jest tak:
nbox login: root
nbox:~# cd /tmp
nbox:/tmp# wget http://e2iplayer.pkteam.pl/precompiled/raw/master/python2.6.6_sh
4_sni_patch.tar.gz
Connecting to e2iplayer.pkteam.pl (87.98.231.87:80)
python2.6.6_sh4_sni_ 100% |*******************************|  1014k  0:00:00 ETA
./usr/
./usr/lib/
./usr/lib/python2.6/
./usr/lib/python2.6/lib-dynload/
./usr/lib/python2.6/lib-dynload/_ssl.so
./usr/lib/python2.6/httplib.pyo
./usr/lib/python2.6/ssl.pyo
./lib/
./lib/libcrypto.so.1.0.0
./lib/libssl.so.1.0.0
nbox:/tmp# sync
nbox:/tmp# sync
nbox:/tmp# reboot
Jeśli chodzi o pendriva to rozumie że  powinienem zainstalować image zamiast do nand to system na  pendriva . A jeśli chodzi o ffmpeg i pycurl to masz może komendę aby to z telnetu zainstalować?  Jeszcze jakbyś mi podesłał jak zrobić system na pendrivie to już bym był mega wdzięczny.
Wykonałem tą procedurę którą podałeś i niestety dalej jak chce uruchomić film to wyskakuje ten błąd , soft był zainstalowany nowy, a pasowałoby to uruchomić  nawet ze względu na to że będe chciał tego pendriva robić:
nbox login: root
nbox:~# cd /tmp
4_sni_patch.tar.gz
./usr/
./usr/lib/
./lib/
nbox:/tmp# sync
nbox:/tmp# sync
nbox:/tmp# reboot
Dodam że czytałem ten opis utworzenia tego pendriva i mówiąc szczerze to mnie osłabiło. Czy nie ma jakieś szybszej i łatwiejszej procedury na stworzenie tego pendriva?
Jak siądziesz i będziesz robił krok po kroku to cała operacja nie zajmie nawet pół godziny, może na pierwszy rzut oka jak jeszcze nigdy nie robiłeś partycji to wygląda to jak jakaś mega trudna robota, ale tak naprawdę to proste jak konstrukcja cepa.Jedyne na co musisz zwrócić uwagę to to jak widziany jest pen w sytemie, jak masz dysk hdd to będzie sdb a jak nie masz dysku to sda i tak musisz niektóre polecenia zmodyfikować.
To będzie pendrive 16 giga.   Po ile giga to podzielić żeby optymalnie nie brakło na nic miejsca?
Masz dysk w tunerze?Tzn.czy będziesz nagrywać na hdd jeżeli go masz, czy na pen jak nie masz hdd, czy w ogóle nie chcesz nic nagrywać?
Witam
Czy 16 GB czasami nie jest zbyt duży ?
mam dysk w tunerze raczej nic nie nagrywam a pen drive mam 16 giga bo i tak ciężko kupić mniejszy.  Sytuacja wygląda tak
nbox login: root
nbox:~# nbox:~# fdisk -l
-sh: nbox:~#: not found
nbox:~# fdisk -l
Disk /dev/sda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/sda1               1       19457   156288348+ 83 Linux
Disk /dev/sdb: 15.7 GB, 15744892928 bytes
255 heads, 63 sectors/track, 1914 cylinders
/dev/sdb1               1        1915    15375840+  c Win95 FAT32 (LBA)
nbox:~#
Edited by DNV
Po próbie  stworzenia partycji wyskakuje mi taki komunikat
nbox:~# fdisk /dev/sdb >
-sh: syntax error: unexpected newline
nbox:~# umount /dev/sdb >
Po co dajesz na końcu symbol ">"?
umount /dev/sdb
fdisk /dev/sdb - naciskamy enter
d - naciskamy enter (usuwamy partycje)
n - naciskamy enter (zakładamy nową partycje)
p - naciskamy enter (primary partition)
1 - naciskamy enter (numer partycji)
system zapyta odkąd ta partycja - naciskamy enter
system zapyta DOKĄD ta partycja +12000M
dajemy +12000M - naciskamy enter
pierwsza partycja założona
teraz druga
n - naciskamy enter
p - naciskamy enter
2 - naciskamy enter
system zapyta DOKĄD ta partycja +128M
dajemy +128M - naciskamy enter
druga partycja założona
p - naciskamy enter (zobaczysz założone partycje)
Na koniec należy ustawić ID partycji SWAP na 82 w tym celu wciskamy t
t - zmienia typ partycji
2 - numer partycji do zmiany i naciskamy enter
82 - kod partycji SWAP
p - w celu sprawdzenia
w - naciskamy enter (zapisanie wszystkiego co zrobione)
Partycje założone
Czy jest dobrze?
/dev/sdb1               1        1460    11727418+ 83 Linux
/dev/sdb2            1461        1477      136552+ 82 Linux swap
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table
nbox:~#
Edited by DNV
teraz mam jakiś format tych partycji robic?
mkfs.ext3 -I 128 -b 4096 /dev/sdb1
mkswap /dev/sdb2 -L swap
 mam wpisać 4096 ? czy inna wartość?
Edited by DNV
ok sformatowało się. Teraz chce przekopiować z nand soft na pena ale coś nie gra bo mam komunikat:
nbox:~# mount -t jffs2 /dev/mtdblock0 /media
mount: mounting /dev/mtdblock0 on /media failed: Device or resource busy
Zrobiłem:
nbox:~# mount /dev/sdb1 /mnt
nbox:~# cp -r /media/* /mnt
nbox:~# dd if=/dev/mtd1 of=/mnt/boot/uImage
8192+0 records in
8192+0 records out
4194304 bytes (4.0MB) copied, 3.769544 seconds, 1.1MB/s
Niestety tuner nie odpala sie z USBA
A jakim cudem z UsbA?Przecież pisałeś że masz dysk, a skoro tak to odpalasz z UsbB.
no ale przecież ja formatowałem pendriva i robiłem partycje na nim.  Dysk oczywiście też mam w tunerze.
Do wyboru strzałkami mam : USBa, USHb, HDD1, HDD2,HDD3 , NAND , MAC2, NFS, U-B4
Edited by DNV
Wybrałem , nie odpala się  cały czas LOAD na wyświetlaczu .   Dodam że  te partycje zostały zrobione na pendrive który aktualnie jest w tunerze. Tak to wygląda aktualnie
nbox:~# fdisk -l
/dev/sdb2            1461        1477      136552+ 83 Linux
Edited by DNV
Widać i dysk i pen, partycja z której chcesz wystartować to pierwsza partycja na penie czyli sdb1, odpal z nand i sprawdź czy w /media/sdb1 jest struktura katalogów taka jak w nand czyli wszystkie katalogi var, usr, lib, mnt, media itd. ew. podmontuj sdb1 np do media/usb i tam zobacz czy są katalogi.
mount /dev/sdb1 /media/usb
ok . Po dłuższym czasie uruchomił się z USHb.
Co nalezy zmienić w fstab aby sie z automatu uruchamiał tuner z USHb ?
Chciałbym też zrobić tą nieszczęsną IPLĘ
Edited by DNV
